Sponsored by: CARiD
97 Discovery won't turn over HELP!
Old Jul 2, 2013 | 01:54 PM
LR97's Avatar
Default 97 Discovery won't turn over HELP!
Hi everyone,
My 97 Discovery has been in my driveway for about 3 weeks now because it won't turn over. It would stall and shut off while driving before finally leaving me stuck on the side of the road. It act as if it does not have gas although I have half a tank. So here is what I did so far to no success;
* Made sure I have gas
* Check fuses
* Installed a new fuel pump
* Changed fuel filter
* Changed spark plugs
Really need this car up and running soon and could use the help of some LR veterans!! Is there anything I should checking/changing??
Fyi, check engine light came on after issue appeared but before the car died. Called several mechanics but no one wants to come out to check it.
Thanks everyone,
Alex
Old Jul 2, 2013 | 08:36 PM
1. Turns over means the engine rotates by the starter when tried. Fan belt moves. If not, then battery, dirty cables and lugs, immobilization, starter relay, frame ground, etc.
2. Won't start - no fuel - check fuel pressure on passenger side test valve (tire valve) on the fuel injection rail - looking for 32-34 psi. Pump should run for about 2 seconds when key turned to position 2.
3. Won't start - no spark - check with plug wire and something shoved into the end of it to manifold, look for sparks when cranking. -
Old Jul 3, 2013 | 09:25 AM
LR97's Avatar
Thanks Buzz! This is really helpful and now know how I will be spending my 4th Have a great 4th yourself!
-Alex
RoverJeep
Mar 26, 2020 03:10 AM
jaw7091987
Nov 29, 2012 01:17 PM
keoni004
Nov 13, 2012 09:54 AM
SolbergFanBoi
Mar 5, 2012 07:05 PM
pdolan1
May 18, 2008 07:36 PM
