Sponsored by: CARiD
97 land rover tranny wont engage
Old Mar 31, 2010 | 06:46 PM
gnotxk9's Avatar
5th Gear
Unhappy 97 land rover tranny wont engage
I have a 1997 LR. It was run without oil, the engine locked while running 25-30 mph. It placed in nuetral and pushed to the curb. Later, it was pulled 10 miles and sat for 5 months. I then pulled it another 10 miles to the mechanic shop. I located a compatible engine and the motor was swapped. NOW , the transmission won't engage in any gear. I called the dealer and was told that the torque converter would not be the issue because it will only bolt one way to the motor, match the 4 bolts. I don't know if the sudden halt at 25_30 mph would damage the inside clutches of the tranny. Or if the problem resulted from pulling it 20 miles in nuetral. I was also told that because it had been sitting, that the transmission has to pressurize in order to engage. ANYONE OUT THERE HAVE ANY REMEDIeS TO THIS PROBLEM! PLEASE ADVISE.
Old Mar 31, 2010 | 06:54 PM
discoxd's Avatar
you might wanna post up in the discovery section if you havent already... it gets a ton more traffic and you are more likely to get a response
cobbcj7
Aug 26, 2013 06:31 AM
gnotxk9
Mar 31, 2010 11:04 PM
discokauai
Jun 17, 2008 07:41 AM
jkid
Oct 20, 2007 09:33 PM
wbudna2
Jul 1, 2005 11:21 AM
