Sponsored by: CARiD
99 disco2 stalls
Old Feb 13, 2012 | 03:47 PM
redrover11's Avatar
3rd Gear
Default 99 disco2 stalls
My LR has 135000 miles on it. It stalls after about 15 minutes of driving. Usually when the outside air temp is below 50 dedrees and sitting at a light. It only does it once or twice then it is ok. It will occasionally hesitate while driving at a steady speed. It restarts immediately. Service engine light came on. I replaced the MAFSand it ran good for several months and started it again. I replaced the crank shaft position sensor to be on the safe side but that did not correct the problem. Any other causes???????
Old Feb 13, 2012 | 06:14 PM
Codes? Fuel pressure test?
Old Feb 14, 2012 | 08:00 AM
redrover11's Avatar
3rd Gear
Thanks. Is there a port that I can use to test FP?
Old Feb 14, 2012 | 08:57 AM
How about codes? When was it last tuned along with 8 mm silicone plug wires?
Old Feb 14, 2012 | 10:27 AM
If a D1 the schraeder valve (tire valve) is on the battery side fuel rail. On a D2 it under the top section of the intake at the firewall/driver's side corner (NAS).
wheston
Sep 16, 2007 04:42 PM
gerumo
Jul 25, 2007 08:51 AM
albertbc
Jan 22, 2007 09:25 AM
RJADM2000
Oct 4, 2006 11:49 AM
RJADM2000
Oct 3, 2006 03:27 PM
