Sponsored by: CARiD
99 Discovery overheating
Old Aug 23, 2009 | 05:39 PM
RescueSr98's Avatar
Default 99 Discovery overheating
Problem began slowly as the summer warmed up. Got worse to the point couldn't drive more than a couple of miles before overheating. Changed the thermostat as it was sporadic at first. Didn't help at first but then learned I had to bleed off the air. Now it is a little better but still over heats when loaded. The fan was turning but you could stop it while running by hand. I assume this is the clutch and have removed the fan to replace the clutch. One aux fan runs when the a/c is on but neither run when engine heats up. Why would one run with a/c but not when hot? checked fuse and it's good. Any suggestions where to go from here?
jayfinn3
Jun 19, 2008 10:46 AM
wadematt
Jun 12, 2008 09:30 AM
bigun
May 14, 2008 08:49 AM
patrickh98039
Apr 8, 2008 07:09 AM
04DiscoverySE
Jul 18, 2006 08:02 AM
