Sponsored by: CARiD
99 Land Rover Transmission Maint Question
Old Mar 6, 2013 | 05:53 PM
DangBritish!'s Avatar
Default 99 Land Rover Transmission Maint Question
Hello - I respect the many opinions here on Land Rovers and the bittersweet joy of owning one. I helped my son purchase his first car a couple months ago and it is a 99 Disco 2 with about 145K miles. I have followed advice from thsi forum and am changing out many old parts - mainly cooling system hoses, thermo, radiator, fan, clutch. But I have a question that I had not seen answered.
I have heard/experienced that in American made cars, if you change the trans fluid on an older car (when it hasn't been maintained) the detergent in teh new trans fluid can "clean up" enough sludge so that the transmission will fail. Meaning loose gunk that can block ports and fluid passages. Drawing on the DiscoMike and SavannahBuzz-types here. What should I do with this DIsco. The fluid is clearly old and spent. Be nice!
Old Mar 6, 2013 | 07:05 PM
NickAdams's Avatar
Well, I work at a shop, but have not always. What I did was change the fluid and filter, and did it again a week later. With previous (non-Land Rover) vehicles, what I have done is change the fluid, keep an eye on it, and sometimes change it again the next day. And then again the next week.
This might sound costly, but really is not, compared to a new transmission.
Old Mar 6, 2013 | 07:38 PM
You would need the multiple changes anyway, as a simple drain leaves behind the fluid in the torque converter. Drain, refill, drive, repeat. About three times ought to do it.
AngelaS
Aug 2, 2010 07:42 PM
blueovaltech
Jun 10, 2008 01:41 PM
blueovaltech
Jun 3, 2008 09:07 PM
rcendo
Dec 22, 2007 08:19 PM
pxm045000
Nov 3, 2007 12:55 PM
