Sponsored by: DashLynx
ABS,HDC,TC,ABS module, fault codes
Old 12-22-2004, 01:08 PM
cottonpatchweims's Avatar
Default ABS,HDC,TC,ABS module, fault codes
I have recently had the ABS,HDC,TC lights come on in my 00 DiscoII(112,000miles). I went to LR who said I need a new ABS module($1800.00) and for my service engine light I need a new air filter box/housing($150.00) because mine is letting air in and throwing O2 sensor codes.
Has anyone here changed the ABS module themselves? I am thinking it looks pretty easy. Disconnect the battery, drain brake fluid, take out ABS module, put in the new one, refill brake fulid and connect battery. Is it this simple and are there any special tools needed? Any advice on making the job easier?
Thanks in advance
Cottonpatchweims
Old 01-14-2005, 01:59 AM
Bait's Avatar
Default RE: ABS,HDC,TC,ABS module, fault codes
Cotton,
You can change the ABS module yourself. However, don't drain the fluid. Just unbolt and install the new one. Chances are you won't even have to bleed it. If you want, just bleed in the conventional manor. You will need to have the Dealer clear the codes.
SEL light ; The air box can set these codes. It allows unfiltered air to contaminate the MAFS. Best bet is to replace both. Light will go out with subsequent drive cycles.
Bait
Mecevans
08-09-2015 02:30 PM
06Range
05-08-2013 09:01 PM
cottonpatchweims
02-10-2005 07:18 PM
Quick Reply: ABS,HDC,TC,ABS module, fault codes
