Sponsored by: CARiD
ac/heater problem... anybody..... help!
Old Jul 9, 2013 | 11:10 AM
dobe1canobe's Avatar
Default ac/heater problem... anybody..... help!
2000 disco 2 100k... so ac and heat work fine except that when i have it on cold/ac and on floor or vent/floor the passenger side (only the floor vents) blows hot air the upper vents blow the correct temp same with the driver side vents and floor vents???? any one ever have a problem like this?
Old Jul 9, 2013 | 11:24 AM
Dampers not operating as they should. The HVAC design depends on the various damper vents moving to correct positions to seal off the air flow thru the heater core. There is no on/off valve, the coolant is always flowing in there.
Also could be that cooling system in front (radiator) is not doing a 100% job, and the heater core is hotter than normal.
Don't depend on heat gauge, it will show center normal fom 130-240F Use a scanner on the OBDII port to be sure.
Old Jul 9, 2013 | 11:43 AM
ok thank you ill start tinkering and see if i can get it.
ls1morethanyou
Jan 12, 2017 10:21 AM
COOTER-GUY
Feb 4, 2011 07:03 AM
Nfbeckman
Mar 17, 2010 07:34 PM
billpa22
Apr 19, 2008 01:20 PM
steve ccc
Dec 31, 2006 11:09 AM
