Sponsored by: CARiD
AC help
Old Oct 8, 2014 | 04:54 PM
TheGageinator's Avatar
Default AC help
On my 1998 Discovery I, my AC compressor will not engage via the ac controls. If i hard wire 12volts positive and a ground wire directly to the compressor, it will engage, and i have ice cold ac. i tried to jumper the high pressure side sensor to see if it was bad. no luck.
All fuses checked OK
Is there a relay in-line, or could my climate control unit be faulty? i have the manual **** controls not digital.
Any ideas would be great! Its hot here in Texas.
Old Oct 8, 2014 | 06:41 PM
abran's Avatar
I'd bet your AC/Snowflake button is faulty.
I have owned 3 D1s that had bad switches. Changed them out and it worked like a charm.
Old Oct 8, 2014 | 09:30 PM
I have a feeling that you are right. Can I replace just those switches or do I need to replace the whole unit? Is there a how to on removing that dash piece? It's super brittle I don't want to break it.....
Old Oct 9, 2014 | 12:09 AM
abran's Avatar
You can replace just the snow flake switch.
Check RAVE manual for instructions.
If that is not clear, PM me your number and a good time to call, I can walk you through it.
Old Oct 9, 2014 | 07:29 AM
Awesome thank you! No I just need to FIND a snowflake switch !
Old Oct 9, 2014 | 11:05 AM
abran's Avatar
I might have good one. I will get back to you in a few days. Be careful when buying used. I would say 50% of the switches I have come across don't work. It would be bad to tear the whole dash apart and install the switch only to see it doesn't work.
Old Oct 10, 2014 | 01:14 PM
Haha yes that would be horrible. ESPECIALLY since lots of this plastic is brittle. If you had a good one you could send that would be super cool!
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
