Sponsored by: CARiD
AC Issue on 1999 Range Rover
Old Aug 29, 2011 | 12:29 PM
rr1999's Avatar
3rd Gear
Default AC Issue on 1999 Range Rover
I recently purchased a 1999 Range Rover. Shortly after, I noticed that there was water leaking on my foot by the brake pedal, whenever I had the AC on. Now, the AC does not work at all. I am wondering if anyone has an idea as to what could be the problem/how to resolve it. Thanks!
Old Aug 29, 2011 | 02:50 PM
Condensation drain(s) could be plugged up, causing the overflow. But they are unlikely to cause total failure of entire AC system. There have been posts about fluid leaking on to blower fan motor and taking it out. When you say AC does not work, could you be more specific?
Old Aug 29, 2011 | 07:43 PM
RoverDoctor's Avatar
4th Gear
Default Plugged A/C Drains
You have plugged up a/c drains underneath the vehicle by the transmission, it is a dumb design, but they trap leaves and debris and allow it to back up,
as far as a/c not working, Im guessing a bad blower relay, back fed system and blew it, change your pollen filters too, they can cause the blower motor to overheat and burn your fusebox, Let me know if I can help more
Matt
"The Land Rover & Jaguar Doctor Service and Repair Center for Orange County California" - Welcome!
Old Aug 30, 2011 | 09:58 AM
rr1999's Avatar
3rd Gear
The blower works, but the air coming out is not cool, like it should be.
Old Aug 30, 2011 | 12:16 PM
OK. So.... sounds like low refrigerant would be the next suspect.
Old Aug 30, 2011 | 09:09 PM
4th Gear
Default A/c Issue
Is the compressor kicking on?
blackandtandisco
Mar 28, 2013 06:57 PM
leddifer
Aug 18, 2010 08:14 PM
leddifer
May 22, 2010 05:42 PM
dms98e
May 9, 2008 08:36 AM
sky2you
Jun 19, 2007 08:44 PM
