AC problem
AC problem
I recently bought a 2004 Freelander HSE and on a recent scorcher, I turned on the AC. The AC worked fine but after a half hour or so a cold mist of water droplets began spraying out of the dash vents. I immediately shut it off and the next time I made a sharp left turn, a small stream of water pored out from under the dash onto the passenger side floor. I'm assuming, like all cars with AC, there is a condensate drain tube and I'm hoping it is clogged and that is all the problem is. Is there anyone out there that can give me some advice?
Yes there is a condensate tube that drains to under the car. I can't see the exact route in the RAVE guide. From https://landroverforums.com/forum/fr...der+condensate there appears there might be a recall on that part, may want to phone the dealer.
Rover Rog
11-06-2013 01:42 PM
Fredzzz
10-11-2013 11:39 AM
XxRoverAllOverxX
03-23-2012 04:49 AM
alleescott
05-31-2009 10:49 AM
traffictech870
10-23-2008 08:03 AM
2004, ac, air, condensate, conditioner, drain, freelander, land, location, peoblem, problems, range, rover, sport, vents
