Sponsored by: CARiD
Advice re Disco 2 purchase
Old Apr 30, 2013 | 03:28 PM
Breadsnapper's Avatar
Default Advice re Disco 2 purchase
i am looking to buy a Disco 2 in the next week or two. Is there anything I need to be wary of ie common faults and what do I need to look for?
Thanks in advance
Old Apr 30, 2013 | 05:08 PM
See our tech area for https://landroverforums.com/forum/di...scovery-21328/ and a side by side comparison of the D1 and D2.
Common problems are:
Overheating, after driving short distance. Heat gauge can't be trusted, the computer makes it show 50% from 130 - 240F. Use a scanner for accurate temps. Head gaskets can make sound of bubbles in water pipes under dash.
Various codes, but owners have been known to paint over check engine light. Again, scanner will tell what is going on.
Ticking sound, after the engine warms up. Caused by several things, one of which is a cylinder sleeve moving up/down, goes away with speed.
Front drive shaft if oem will fail, has sealed grease joints. A rebuild in our tech area, or aftermarket shaft.
It is best to have a mechanic make a pre-purchase inspection.
roverparty
Jun 14, 2015 03:31 PM
New2Disco
Jun 29, 2013 11:34 PM
leftfield6
Jun 10, 2013 11:37 AM
IMurray21
Oct 16, 2008 07:26 AM
bigorangevol
Jan 24, 2007 05:17 PM
