Air bag fault
Air bag fault
Hi Guys
My 98 RR has had the srs light on for about a year now,I have checked evrey connection and even replaced the modual with a known good one and no luck.
The cruise does not work and there is an aftermarket radio so the steering wheel controls won't work anyway but the horn does work.Could my problem be the rotory coupling and is there a way to test it? PS there were no side air bags in 98 so an I correct in assuming no seat connections either?
The SRS system has an independent ECU, so you may need an advance shop or dealer to look at it with something more than your scanner. The rotary coupler could be checked, but your problem may be somewhere else. As an example, you could unplug cruise control module, and meter the inputs from the buttons, to see if they are changing when pressed (easier than taking apart rotary coupler) -
kbarker27
10-13-2023 04:03 PM
06Range
05-08-2013 09:01 PM
cardinal77
01-20-2012 02:52 AM
