Sponsored by: CARiD
Amp meter- showing 30+ amps
Old Apr 17, 2013 | 05:38 AM
stephenaustralia's Avatar
4th Gear
Default Amp meter- showing 30+ amps
Hi there,
Ive just put in a new coil, codenser and points.
When i now start the car, the amp meter now shows 30+ amps.
I appreciate i havent yet set the timing, but can anyone assist and shed some light.
I took a photo before i replaced the coil, and have two conections on one side of the coil and the other side has a single connector which then connects through to the codenser in the distributor cap.
many thanks for any advice
Old Apr 17, 2013 | 05:45 AM
My Jedi powers are weak, I can't see the year and model of the vehicle. Help me Obiwan....
Old Apr 17, 2013 | 05:46 AM
4th Gear
sorry she's a series 2- 1965 swb
Old Apr 17, 2013 | 06:28 AM
Here is a wiring diagram. That high a charge indicates battery was discharged quite a bit, it should drop back down. Wiggle harness, you may have a a short to ground. Or bad voltage regulator.
File Type: pdf
Old Apr 17, 2013 | 06:43 AM
4th Gear
many thanks savannah B- great help
Old Apr 17, 2013 | 12:01 PM
I guess if you have truck key on, but not running, the amp gauge would be negative. If you disconnect coil and condenser, that may move a lot closer to zero (center). A bad condenser could do this, depending on where it is hooked up.
You have no idea how much drool would be produced if you posted photos.
BTW, your golfer looks great in a green jacket. First time the Master's was won by an Aussie. I actually played that course the first time I took up golf. Shot a 72. Got so damn excited I could not play the second hole!
Old Apr 17, 2013 | 12:12 PM
antichrist's Avatar
Is your battery fully charged? Your generator could be putting out 30a trying to charge the battery.
Also, be careful which wiring diagram you use. Land Rovers were positive earth until '67. Yours may or may not have been switched to negative earth.
Also, a '65 would be a IIa.
Braap
Apr 1, 2013 11:57 PM
'BamaBoy
May 24, 2012 12:45 PM
Savannah Buzz
Jan 13, 2012 03:37 PM
philander
Aug 19, 2011 04:20 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
