Sponsored by: CARiD
Block heater for Td5
Old Feb 7, 2021 | 05:01 PM
TD50below's Avatar
Default Block heater for Td5
Hi. I’m in the process of buying a 90 with a TD5 in it (my first LR in 30 years), and due to where I live I’m going to need some form of engine heat to ensure that it will start (it was -44c this morning, -55c with the windchill. Do you have any idea how many cups of tea it takes to keep warm in those temps?)
My first choice is a simple block heater, but the problem is that no-one makes one. Not LR, and I haven’t been able to find an aftermarket one either. I’ve just heard of a friend of a friend who has a 300tdi (for which there is also apparently no such thing as a block heater), but he found one from a Ford tractor that fits and, he says, melts the snow off his bonnet.
The core plugs in a TD5 are 28mm and 46.5mm, apparently. I can find a 28mm block heater on Amazon for $100 and it may fit, but I’d love to hear from someone who found one that did for sure fit – tried and tested.
I’m aware that there are alternative options (e.g. Webasto), but that will be $3000 fitted whereas a block heater is a fraction of the cost and I can fit it myself. If I can find one. Someone somewhere makes a block heater that will fit. It won’t have been designed for a TD5, and whoever makes it may not know what a TD5 was if it fell on them out of a tree, but it will still fit. Can anyone help? Thanks!
AKDiscovery
Jan 28, 2026 08:55 AM
K9Hexe
Nov 17, 2023 02:35 PM
houm_wa
Sep 11, 2013 10:56 AM
chris_craft
Dec 7, 2008 07:22 PM
newBrover
Jan 21, 2007 02:36 PM
