Sponsored by: CARiD
Blown head gasket
Old May 14, 2008 | 07:33 AM
Tamango's Avatar
4th Gear
Default Blown head gasket
I have a 1997 Land Rover Discovery.
I was driving my Land while it was overheating.When i finally pulled over the car was so hot that it wouldnt start. I was driving with broken radiator cap. I replaced the radiator cap.
Everything was oka after that for a little while. The land started to overheat again. This time there was a lot of white smoke coming out of my my tail pipe. I was told by someone who checked under my hood that have blown a head gasket.
I cant aford a head gasket job. and dont know enough to do it myself.There is a solution called Therogasket that cost about $100.00. Would this product work and has anyone heard of it.
Old May 14, 2008 | 08:35 AM
Default RE: Blown head gasket
Why did you not pull right of the road, why did you go drive it again? Yes, it has at the least a blown head gasket, possible cracked head and or possible dropped sleeve.
The magic brew you have mentioned won't work because of the possibility of a cracked head or dropped sleeve.
You have to have the heads pulled, you have no other way to go.
Old May 14, 2008 | 05:22 PM
WolfPack's Avatar
Yea....bad move on driving it while over heating.....
You're stuck....gotta pull the heads. Even if you were to try the gasket magic stuff, what's going to stop if from just blowing right thorugh just like the coolant? Maybe if you had tried that right at the beginning...but now...head gasket job.
Old May 16, 2008 | 06:01 PM
DiscoSam2's Avatar
Plus the aluminum block can distort when it gets too hot,then might as well toss it,might have that checked as well,place I take mine says thats not all too uncommon
Old May 16, 2008 | 06:20 PM
WolfPack's Avatar
Very common indeed when driven while overheating. The problem is aluminum block and iron heads. Different expansion rates = bad.
Qtiep
Feb 13, 2019 06:46 PM
NiveK1970
Sep 9, 2009 05:26 PM
StevenDiscoII
Aug 11, 2009 04:48 AM
94disco3.9
May 13, 2008 06:06 PM
kevbo
Aug 30, 2007 06:30 AM
