Sponsored by: CARiD
Brake ?
Old Mar 4, 2009 | 05:47 PM
Sbwood's Avatar
Default Brake ?
I took mt 2002 Discovery to the dealer to check my squeeking brakes, he said my rear pads were 1 mm ( I think) and I needed pads and rotors. Does that sound right? Is it common to replace rotors with break pads on Land Rovers? He would be happy to do this for $603.00. Any advise would be great. If its against the rules to post price , sorry I will edit the post.
Thanks,
Stephen
Old Mar 4, 2009 | 09:08 PM
roverguy7's Avatar
if youre down tp 1mm, and the rotors had a lip, then you were probably metal to metal on the lip. anyway, yeah, its a soft rotor, thats why they cant be turned, too soft, and they go decently quick. general rule is every other set of pads, youll need rotors
Old Mar 4, 2009 | 11:41 PM
Sbwood's Avatar
Thanks for the info roverguy7!
Old Mar 5, 2009 | 10:03 AM
How many miles on your truck, how mechanical are you and if you could buy pads and rotors for $200 would you want to try and do you brakes yourself?
Old Apr 2, 2009 | 08:53 PM
KarenCaren's Avatar
For me, this is the time to get a better rotor and pads. It may cost a little but I think getting a good rotor and pad will last longer.
______________
If you ain't first your last!
ford timing cover
Old Apr 3, 2009 | 08:18 AM
For less then $200, you can buy good pads and rotors from Atlantic British and install then in a hour.
SolAeon
Jul 10, 2012 09:05 AM
ctystrickland
Feb 15, 2011 07:54 PM
tibyABv6
Jan 7, 2011 06:02 AM
Florida04RR
Mar 10, 2010 06:09 AM
bigbris1
Jul 3, 2007 08:02 PM
