brake issues
cross drilled rotors soak up water and rust out and cause issues with warping. A real pos on an offroad vehicle. Notice how no Supercharged range rovers and range rover sports have drilled rotors from the factory.
if you are burning them up quick its your driving. not the parts. But if you can find ones that are supposed to last longer they will squeal like crazy.
If water caused slotted and drilled rotors to rust then warp, would would performance companies like Mercedes, BMW, Porche and most of the other European companies use them use them?
hey all thanks for all the info on the brakes i found my abs light is just a wheel sensor. I have fixed everything else mechanical with it so far but still fighting with electrical issues what a night mare but i have learned alot through this forum again thanks to everyone in the rover world
lonely king
06-21-2008 12:18 PM
bavarian_range89
12-29-2007 02:56 AM
