Sponsored by: CARiD
Brakes
Old Nov 29, 2012 | 04:10 PM
garry hotrod's Avatar
3rd Gear
Default Brakes
Hi all having trouble with brake pedal pressure, i changed the rear brake pads but found caliper pistons wouldnt go back so changed the calipers bled them but no pedal, took it to a garage they bled it but said it needs a master cylinder got 2nd hand 1 took to garage they fitted it still no pedal they now saying maybe abs modulator but could be something else, They told me it has been bled under pressure. Any help would be appreciated spent £130 on it still no further/nearer to solving the problem, Garry
Old Nov 29, 2012 | 04:46 PM
jafir's Avatar
What kind of land rover do you have?
Old Nov 29, 2012 | 08:47 PM
Can you better describe "no pedal"?
Will it not move at all?
Does it move alittle but then fight you?
Do you get a pulsing in the pedal?
Old Dec 2, 2012 | 05:06 AM
3rd Gear
Hi i have a discovery y reg 2001 td5, Garry
Old Dec 2, 2012 | 07:08 AM
Bkreutz's Avatar
The procedure for bleeding starts on page 70-30 of the RAVE manual, the sequence is different for RHD vehicles. They give both sequences there. If you don't have RAVE, it is available for free here. land rover service factory manual RAVE download land rover resource, service manual, workshop factory manual, download, rave, vehicles including discovery, series, defender, range rover, freelander, LR3, Handbooks, Catalog, Catalogue, Land Rover Inte
FightOnUSC79
Nov 26, 2010 09:43 AM
1eyescooter
Feb 1, 2007 11:12 AM
1eyescooter
Jan 15, 2007 08:48 PM
BigMike
Mar 30, 2006 09:45 PM
bakerww
Jan 30, 2005 10:36 PM
