Sponsored by: CARiD
Broken screw in rear license plate insert
Old Mar 28, 2016 | 07:19 PM
azeleniak's Avatar
Angry Broken screw in rear license plate insert
so the insert (nut) for the license plate bracket was free spinning last time i took the plate off of my 2003 disco. I was trying to get the screw out when it broke off and is now stuck in the free spinning insert. I would say it is done and needs to be replaced. Looking for help on how to find this part and how to replace it.
Old Mar 28, 2016 | 07:45 PM
BritishautoworksSD's Avatar
Sounds like you need to either replace the license plate bracket. Can you get the plate of the bracket?
Old Mar 28, 2016 | 07:54 PM
azeleniak's Avatar
Its not the bracket it is the insert that is in the actual tailgate. The insert that the bracket screws into.
Old Mar 28, 2016 | 08:05 PM
You need to remove the insert. Installed a new nutsert. I don't remember if a screw or bolt holds the frame. Old Range Rover Classics, I use a nutsert.
http://www.autozone.com/screws-pins-...late-fasteners
Or use these for the screw with plastic insert.
Earl Callow
Feb 6, 2009 03:08 PM
BradHall
Nov 21, 2007 05:09 PM
RDM3
Freelander
Dec 15, 2006 04:56 AM
KWAYZ
Dec 7, 2006 09:09 PM
