Broken Yoke 97 Disco
I'm trying to find a new front driveshaft yoke, the shaft is fine and the other side of where the u joint connects with the 4 bolts but the u joint and yoke are destroyed. anyone know where to get just the yoke no shaft? thanks!
If you do some google-fu you should be able to find the part numbers of the spicer/moog/whatever components that make up the shaft.
It might not be easy, but you should be able to find it with perserverance.
melmanc55
May 23, 2009 05:14 PM
