Sponsored by: CARiD
burning coolant after all repairs
Old Oct 21, 2010 | 12:01 AM
mara9205's Avatar
4wd High
Unhappy burning coolant after all repairs
my discovery se7 2003 , had replaced all headgaskets, cables, hoses, new air conditioner motor, pads and rotors, new oil, new coolant, and all this past month and still burn coolant, can anyone help pleaseeee. it never gave me problems before except 3 years ago that i change the headgaskets.
Old Oct 21, 2010 | 08:56 AM
SDinDS's Avatar
Did you have a machine shop check the heads? Sounds like there might be a crack in one if it's still burning coolant.
Eric
Old Oct 21, 2010 | 09:24 AM
How many miles on the engine, did you use a new t/stat as well as new head bolts?
Where is it leaking from, have you done a coolant pressure test yet and did you or a shop do the work?
Old Oct 22, 2010 | 04:44 PM
mara9205's Avatar
4wd High
Smile burning coolant
Thanks Mike, I asked LR if they check or replaced the t-tat and they said no and when they cheched they said that I Had a leak going to the t-tat and that i need a new one. Also thanks for telling me about the little fan thats next to the steering wheel on the dash board cause they checked the noise and showed me was coming from there. Your help its been very appreciated. You are an excellent mechanic and person.And thanks to Eric your help is been very helpful too.
Anxious Jim
Dec 11, 2013 12:39 PM
caymandrew
Mar 18, 2013 12:11 PM
pwaltrip
Jun 12, 2012 05:55 AM
Snafu / Disco Fries
Dec 7, 2011 06:30 PM
Phototone
Apr 4, 2008 10:26 PM
