Sponsored by: CARiD
Can't remove lower radiator hose
Old Mar 3, 2013 | 02:08 PM
KOz's Avatar
KOz
Default Can't remove lower radiator hose
Any suggestions / tips? I'm not a complete moron.
Would like to save the hose, if possible, it's not warped.
Old Mar 3, 2013 | 03:17 PM
If its sticking like that it means its bad.
Cut a slit length wise starting at the end you need to take off, peel it back until you get it off.
Old Mar 4, 2013 | 05:09 AM
KOz's Avatar
KOz
Finally got it off. It was an hour or so of pulling from under / from over / left hand / right hand / Cursing and kicking.
I will replace the hoses.
Old Mar 4, 2013 | 06:18 AM
antichrist's Avatar
A cotter pin removal tool usually does the trick for me.
When installing them I usually smear silicone grease inside so they aren't as likely to vulcanize to the fitting.
Old Mar 4, 2013 | 07:24 AM
jafir's Avatar
I've got a similar tool that was actually sold as a radiator hose removal tool. I guess I know what else I should use it for now.
Old Mar 4, 2013 | 10:35 AM
antichrist's Avatar
Also for removing/installing window gaskets.
Old Mar 4, 2013 | 12:05 PM
jafir's Avatar
I'm not sure I'm brave enough for that yet. My new-to-me defender is ex-mod and has about 5 layers of paint on it, including the window seals, so I was thinking about replacing them. How difficult is it?
Old Mar 4, 2013 | 05:58 PM
antichrist's Avatar
Which ones? But if they aren't cracking or leaking I wouldn't bother unless you're stripping it for a respray.
Old Mar 4, 2013 | 06:48 PM
jafir's Avatar
Pretty much all of them, but the one in the windscreen and the small windows in the back of the hard top are what I was thinking about. I don't think they leak, and I wouldn't know if they are cracking because there is so much paint on them.... but yeah, I should probably wait until I decide if I want to paint it.
Rock Sing
Jan 8, 2013 01:51 AM
kenk
Jul 18, 2011 09:29 AM
dhaselhorst
May 15, 2010 08:03 PM
racdisco
Feb 24, 2007 08:52 PM
Rcraig
Aug 4, 2005 10:11 PM
