Sponsored by: CARiD
Catalytic Converter??
Old Jan 7, 2008 | 11:11 PM
dirtymorgan's Avatar
5th Gear
Default Catalytic Converter??
I have a '99 Disco II and have had problems with it running poorly, especially on the highway. It seems as if it is having a fuel problem, it is underpowered and struggles when you give it gas. I took it to a small LR shop and they said it was the catconverters? Is this a common diagnosis for the problem? Do these things really go out that fast? My truck only has 59K miles on it. Is there another issue I should address before doing this repair?
Thanks a bunch!!!!
Old Jan 8, 2008 | 07:27 AM
Default RE: Catalytic Converter??
That shop is way off base, if you had bad cats, you would have a check engine light throwing cat codes.
What has been done to the engine as far as tune up related work, what octane gas are you running????
Old Jan 9, 2008 | 08:54 AM
5th Gear
I had it tuned up about a year and a half ago, I am running 90 octane gas in it now, for a while though my brother had it in New Orleans and I think he ran 87 in it. It runs fine around town for the most part but on the highway it bogs down. If you kind of "feather" the throttle a bit you can get it up to highway speed but other than that you can't.
Old Jan 9, 2008 | 09:52 AM
Send me your tele number and a good time for me to call you, I'
ll walk you thru things to check.
jwmstang
Aug 4, 2022 02:30 PM
JKK
Mar 4, 2006 01:29 AM
arocena409
Feb 13, 2006 01:08 AM
SUMOSINO
Feb 9, 2006 10:04 AM
mgm777
Jul 27, 2005 05:01 AM
