Sponsored by: CARiD
common problem with gear shifter?
Old Sep 15, 2014 | 02:14 PM
Bwatson94's Avatar
4wd High
Default common problem with gear shifter?
So i got my 99 disco sd on Saturday and it doesnt run. When they parked it for me i noticed they left it in neutral, so i put it in park and now its stuck there. It doesnt have a battery in it, but i dont think that should matter for this. I've found that this is a common issue, but im not able to pull the shift **** off. Any ideas on how to get it off and fix the problem?
Old Sep 15, 2014 | 02:31 PM
fishEH's Avatar
The shift lock solenoid won't release the shifter until the brake light switch tells it to. You need power for that to happen. So toss a battery in there or hook up some jumper cables, turn the key to Pos II, press the brake and shift into Neutral. You can now disconnect the battery but you won't be able to remove the key. Once you get it out of Park you can open up the console and actually remove that solenoid. That will allow you to shift at will with no regard to the brake being pressed(not necessarily a good thing).
Old Sep 15, 2014 | 02:38 PM
Bwatson94's Avatar
4wd High
Oh okay, that makes sense now. Thank you. Hopefully i can have it running soon. I got this for a new toy but im anxious to get it running and find trails
Old Sep 15, 2014 | 03:49 PM
Bwatson94's Avatar
4wd High
Problem is solved, thank you. Now back to getting it running lol
Old Mar 3, 2018 | 05:02 PM
1811SAR's Avatar
Default D2 Won't shift from forward gears to Reserve/Park
Originally Posted by fishEH
The shift lock solenoid won't release the shifter until the brake light switch tells it to. Once you get it out of Park you can open up the console and actually remove that solenoid. That will allow you to shift at will with no regard to the brake being pressed(not necessarily a good thing).
Would that be the same for an opposite problem? My son has all his forward gears but it won't let him shift into Reverse nor past it for Park. Can't get to Park so he can't release the key...
He got it home and it's out front with the key in the ignition and the the Brake on.
Any help would be greatly appreciated.
Cheers,
G
Old Mar 7, 2018 | 03:13 PM
The Deputy's Avatar
Pull up the shifter housing (piece that shifter handle runs through), grasp firmly with both hands (rear and forward corners) and pull straight up, (no need to remove shifter ****), kind of a controlled pull though...since there are a few wires attached and the plastic track for shifter sliding-cover...and then look for loose change below. Our 03 had about three dollars in change wedged down there, and wouldn't go into park at times.
Brian.
Old Mar 8, 2018 | 09:28 AM
1811SAR's Avatar
Thanks Brian...we'll give it a try today...
Cheers mate,
G
MiDisco2
May 31, 2014 09:04 AM
swfqk6
Jan 31, 2014 10:22 AM
baburhan
May 26, 2011 06:37 PM
jonasm
Dec 23, 2008 05:51 AM
alanroberts50
Nov 20, 2007 08:32 PM
