Sponsored by: CARiD
coolant leak
Old Jan 25, 2015 | 04:58 PM
hinton5408's Avatar
Default coolant leak
I blew a hose on the upper radiator hose the other day and reaplaced the upper hose, thermostat and lower radiator hose. Now when the engine heats up coolant spits out the screw on upper right side of the radiator. Its the same side the upper hose goes in and the smaller hose from the reservoir to the radiator. Does anybody have any ideas?
Old Jan 25, 2015 | 05:58 PM
OverRover's Avatar
I'll take a guess... you over tightened the screw that mounts the fan shroud. It's common and a jackass design. Some guys have used 2 part epoxy putty like JB Weld, quick steel, etc. to fill the hole and then tap with a shorter screw. Do a search on this forum, but here...
Like this 5th post> Radiator fluid leaking from top screw mount for fan cover. - Australian Land Rover Owners
Old Jan 27, 2015 | 08:11 AM
drowssap's Avatar
yup, new radiator ebay or rock auto about $150
ZMonet
Jun 24, 2016 04:00 PM
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
nolabrooke
May 21, 2010 09:33 AM
lipadj46
Jul 8, 2009 07:41 PM
