Sponsored by: CARiD
Crankshaft position sensor
Old May 13, 2011 | 08:15 AM
jroebuck's Avatar
Exclamation Crankshaft position sensor
How do I replace the crankshaft position sensor on my 98 discovery?
Old May 13, 2011 | 10:50 AM
Chris-bob's Avatar
Download the RAVE in my signature. It will answer 99% of your questions.
Old May 13, 2011 | 11:32 AM
What is wrong with yours?
here is a picture of one for your truck.
Attached Thumbnails Crankshaft position sensor-land_range_rover_discovery_defender_crankshaft_sensor_err6119.jpg
Old May 13, 2011 | 12:14 PM
jroebuck's Avatar
Question idk
Well it dies when it idles, and I went to crank it last night, it turns over, batterys fine, spark plugs, wires, and timing chains are fine. But won't crank.
Old May 13, 2011 | 12:47 PM
You have too many fines there. How do you know all those are fine, what is the charging system voltage, how did you check the change, although it has nothing to do with your problem.
When was the last time you replaced your fuel filter? Might want to start with a fuel pressure test.
EVN137
Oct 6, 2024 12:48 PM
ViennaDisco
Sep 25, 2010 04:16 PM
hendoc3
Jun 25, 2010 11:56 AM
vserduchka
Dec 4, 2009 05:57 PM
smi8387
Feb 7, 2006 01:15 PM
