Sponsored by: CARiD
crankshaft pulley
Old Feb 5, 2018 | 11:53 AM
machinetech's Avatar
Default crankshaft pulley
Anyone know what way to loosen crankshaft pulley. Looking from front is it clockwise or counter clockwise. Its a 97 discovery.
Old Feb 5, 2018 | 12:38 PM
Sixpack577's Avatar
Counter clockwise
Right hand thread
Tight, has 200'lbs on it
Old Feb 12, 2018 | 12:00 PM
annette's Avatar
use a Loooooong pipe on your bar
Old Feb 12, 2018 | 09:04 PM
Best4x4's Avatar
Or go old school and remove the fuel pump relay so the engine won't run, then use a long breaker bar and a 15/16 socket and place it under the frame rail and secure it into place with a zip tie. Then use the LR to loosen it for you! Give it a small bump of the key and the engine rotating will loosen the bolt.
Old Feb 13, 2018 | 10:03 PM
number9's Avatar
Or go old school
Major advantage is not having to prevent engine rotation when breaking the bolt loose. Usually quick and easy. We did the same a few months ago on a friends Nissan and he was amazed.
lo377
Nov 3, 2014 10:00 AM
ruining
Feb 12, 2013 12:32 AM
928paul
Dec 12, 2011 09:05 PM
lipadj46
Nov 15, 2009 07:09 PM
Disco.Jay
Mar 4, 2006 09:08 PM
