Sponsored by: CARiD
CV Joint, Bearings, HUB, Axle?????
Old Aug 3, 2007 | 10:24 AM
DISCOHAITI's Avatar
8th Gear
Default CV Joint, Bearings, HUB, Axle?????
I've gone through a number of brake pads, changed my steering stabilizer links, steering damper, rotors, shocks, tie rods, sway bar, bushings, etc etc. Basically a whole new front end but in the end I have the same problem...when I brake the steering wheel shakes. More so once the pads wear alittle. I also have a rattling noise coming from the front end but it goes away when I step on the brakes slightly and the left side pads wear out quickly. I was told this may be from my front bearings. Question is can I take apart the hub and fix this or do I need to replace the bearings with a whole new assembly and if so what do I buy?? Do I buy the hub assembly that comes with an ABS sensor or a CV joint or the left side axle itself? Please help cause I've been dealing with this for the last 8 months. The repairs I have made have been well spent since I wanted to replace these parts anyway but the rattling and shaking are not only getting on my nerves but I am afraid one day the hub, wheel or axle my break. This is an overseas car so bringing it to a dealer is not the be option as they charge $300 for an oil change! HELP!
Old Aug 3, 2007 | 12:39 PM
Default RE: CV Joint, Bearings, HUB, Axle?????
What year, model and mileage??
Mike
Old Aug 6, 2007 | 11:14 AM
DISCOHAITI's Avatar
8th Gear
I have a 2000 LR Discovery Series II. with 76K miles.
Old Aug 22, 2007 | 02:26 PM
sideburns's Avatar
needs a grand slam,rotors and pads all the way around
Old Aug 27, 2007 | 07:57 AM
DISCOHAITI's Avatar
8th Gear
Hey Mike, Any ideas of what the problem could be? Like I said I replaced everything and the problem is still there. Do you think it will help if I try changing the rotors again?
Old Aug 27, 2007 | 09:09 AM
Why don't you give me a call and lets ponder it?
303-862-7680
7 am to 8 pm
Colorado
Externet
Nov 21, 2012 10:44 AM
adigerol77
May 6, 2011 03:29 PM
KeizerRover
Jun 26, 2009 09:26 PM
sanmigmike
Aug 24, 2006 03:37 PM
