Sponsored by: CARiD
D2 TD5 Failing to start.
Old Dec 13, 2017 | 03:22 AM
DaveG's Avatar
Default D2 TD5 Failing to start.
Hi, brand new member so excuse the immediate question.
I have a UK spec D2 TD5 with 145k on the clock. I have just replaced the transfer box and when I went to start it after the work it would not turn over.
Battery is good (I put it on chsrge to make sure). I'm getting full electrics but when turn the ignition key all I get is a faint click from the relays in the engine bay fuse box. Starter solenoid doesn't click. The only other sound is occasionally the suspension compressor kicking in for a second or two.
Went back under to double check the sensors on the transfer box (reverse light switch and neutral sensor) both seem fine.
Any suggestions on why it won' turn over? I don't have a fault code reader unfortunately.
Thanks in advance.
Old Dec 13, 2017 | 06:32 AM
mollusc's Avatar
Did you press the inertia switch on the firewall?
pgaukroger
Feb 29, 2016 05:56 AM
AK Rover
Mar 9, 2009 11:03 AM
redr0ver02
Freelander
Jan 24, 2008 08:24 PM
trini defender
Defender
Dec 11, 2006 05:14 AM
gmalezis
Jul 24, 2006 07:12 PM
