dash lights come on
it could be couple things. first of all it can give you a code for wheel speed sensor . there is an updated overlay harness for these sensors that pretty much just eliminates the connector on the fire wall and it has your pin it straight to the abs module. the other one it can be a abs modulator shuttle switch failure code. there is new updated parts for this wich consist of new modulator switches and new coil packs for the modulator itself. and last but not least it can be a brake switch. good luck
TexasDiscovery
08-06-2013 12:54 PM
