Dead Battery after Coil Conversion
I just got my Daughter a 2000 Disco II and completed the coil conversion on Wednesday following the instructions in the Disco II forum. This morning he battery is dead. I pulled Relay 5 and Fuse Link 9 under the hood. I did not pull any fuses from the interior fuse block because the SLS fuse also shows to be for the ABS. Can this fuse be pulled without affecting the ABS? Should I also pull the compressor?
b_woodroaster
11-05-2010 08:54 AM
