Sponsored by: CARiD
Defender 90 (NAS '97) OBD Codes
Old Sep 24, 2016 | 07:37 PM
markfab's Avatar
8th Gear
Default Defender 90 (NAS '97) OBD Codes
Can anyone assist me with OBD codes P1317 & P3999 ?
I believe P1317 means ABS Rough Road Line Low Fault, but my '97 D90 doesn't have ABS.
No idea what P3999 - cant find that code anywhere...
Thanks in advance !
Old Sep 27, 2016 | 10:22 AM
If memory serves the 1317 on a D90 is a tune up issue. like cap rotor plugs and wires time. The p3999 is a code reader fault code. It means it can't read or doesn't understand a code that is in the system
Old Sep 27, 2016 | 03:22 PM
markfab's Avatar
8th Gear
Thanks ArmyRover ! I'm new to OBD codes & I sense I've got a lot to learn. Are OBD codes 'model' or 'manufacturer' specific? And any idea where I can locate a definitive OBD code list to assist w/ the troubleshooting? Since i'm trying to pass CA SMOG, I'm also wondering about the P3999 fault code & how to resolve it....Appreciate your help !
ps - I'm new to the Forum & I posted on General Tech Help. Should I have posted this on the Defender forum for any reason? Thanks!
Old Sep 28, 2016 | 07:06 AM
WaltNYC's Avatar
Here is a link to the OBD manual. Your codes are a bit strange (or I'm not reading the manual correctly). Are you certain is is a 1997?
https://landroverforums.com/forum/di...02/#post580926
The other suggestion I'd have is to check out defendersouce.com . This forum is great but that forum is more specific to Defenders.
Old Sep 28, 2016 | 11:15 AM
markfab's Avatar
8th Gear
Appreciate the info WaltNYC. I'll check out the OBD manual & Defender forum. My Defender's definitely a 1997, but your comment makes me question the tech that pulled that OBD codes. Bought my own code reader to confirm readings.
Do you know if P1317 is the same for a Disco as a Defender ?
Old Sep 28, 2016 | 11:55 AM
mollusc's Avatar
Your is probably OBD1, yes? I don't know if there was room for manufacturer-specific codes in that spec, but OBDII definitely allows for them. In addition, there are separate sections of the spec for ABS codes.
Old Sep 28, 2016 | 12:18 PM
markfab's Avatar
8th Gear
Pretty sure its OBDII. Has the 16-pin connector & is a 1997 NAS. Thought OBDII was '96 & newer !? CA law doesnt permit Pep Boys, et al, to read the codes so I ordered a scanner arriving today. Should confirm the code readings...THEN I can start sleuthing the problem to pass SMOG.
Thanks for the reply!
Old Oct 2, 2016 | 10:17 AM
abran's Avatar
if you are in socal I can read the codes with my Autologic, it will give the actual land rover explanation of the code with suggested fixes.
call me. 949.413.7396
johnkbl
May 3, 2010 06:19 PM
remotemedic
Feb 18, 2010 12:34 PM
alemurill
Jul 9, 2008 10:16 AM
FMV
Jun 25, 2008 07:59 AM
URBANOFFROAD
Apr 16, 2007 01:28 AM
