Sponsored by: CARiD
Died in car wash, won't start, just cranks.
Old Jan 17, 2009 | 03:13 PM
kayaku's Avatar
Default Died in car wash, won't start, just cranks.
I drove my 98 disc through a car wash today, with a underbody spray. It died in the middle of the wash while running. My guess is ditributer coils got wet. Had it towed back to my heated garage and it's just sitting now hoping whatever got wet will dry up and start.When I turn the key itwill just crank, few times the engine turned over, or tried to. I just tried it now and whenI turned the key the first time it did nothing, no starter crank. Returning the key to the off position, and trying again it did crank strong but still no luck getting it to start.I'm not sure what it's called exactly but I read somewhere in the forum about a master reset, kill switch, lockout or something along that idea. Any help would be greatly appreciated.The plugs and wires are new andI used dielectric grease on allthe boots when I replaced them a few months ago.Thanks for any help offered. ~ Kevin
Old Jan 17, 2009 | 10:34 PM
Jasondizzyd's Avatar
Default RE: Died in car wash, won't start, just cranks.
My best guess is a connector got knocked loose while it was getting sprayed underneath. Check to see if its the crank position sensor just a thought. It shouldn't be anything serious.
Old Jan 18, 2009 | 08:42 AM
First, go get a 2 hour charge on your battery, can't do anything with out that.
D1's have a ECU under the hood, passenger side of the firewall, that may have gotten wet, if so it won't start till that dries out, takes forever or open it up and dry it out.
Wish I could help you with the plug, was it hooked up before you hit the car wash?
Old Jan 18, 2009 | 10:11 AM
kayaku's Avatar
Update- Thanks for your help. Sat in the garage all night at 75 deg ( 6 deg outside) Fired right up and ran perfect like nothing happened this morning! Note to self... Don't drive my Rover super slow over high pressure underbody sprayers! I learn something new everyday with this toy!
Old Jan 18, 2009 | 10:15 AM
kayaku's Avatar
I was a little annoyed when the owner of the car wash said " Thought them things like water" Oh well...
Old Jan 18, 2009 | 10:24 AM
D1's don't for the most part, D2's love it.
Mike
nosup4u
Jun 16, 2014 02:54 PM
jrkstore43
Sep 28, 2012 04:16 PM
texmanmoore
Dec 5, 2010 12:45 PM
mdf27
Feb 12, 2010 05:24 PM
bobbydave
May 14, 2008 08:52 PM
