Sponsored by: CARiD
Disco 2 front windows
Old May 9, 2016 | 09:17 PM
Sebc's Avatar
6th Gear
Default Disco 2 front windows
Have an issue with a 2002 disco 2, my front windows quit working but I can hear the clicking in the BCU. Is there another element that could make both front windows no longer function? I've looked around and can't seem to find any fixes for info for this. Be glad to get any input.
Old May 10, 2016 | 11:00 AM
Joemamma1954's Avatar
When my son's 04 did this same thing, we found the motor on the window was gone. He had picked up a couple of regulators from pick-n-pull a couple of months earlier and we removed the motor and and replaced it and worked great. While we had it apart, I sprayed the rollers with some of the dry lube and it was very quiet. The Drivers side motor was running, but the reduction gear inside the large round cover on the motor was stripped off the shaft, so we replaced that motor, lubed rollers and now it is working also. I hope this may help you.
Eric at Lucky8 has replacement motors for 25.00 for forum members. This is my route when mine on my 03 go out.
I am in Austin, and work at Solaro Estate Winery in Dripping Springs.
Old May 10, 2016 | 11:02 AM
Also, I have some of the 3d replacement rollers on me, if you find the rollers are broken.
just let me know.
Old May 11, 2016 | 05:28 AM
Sebc's Avatar
6th Gear
Thanks for the info, I've replaced both front motors and window lift units already. Since both windows died at the same time I'm inclined to think its something else. If you ever need to borrow a code reader I have an I-car soft, I have the deli on 290 Lox, Box & Barrel swing by!
Old May 11, 2016 | 07:22 AM
number9's Avatar
Here's info from electrical manuals for you to consider.
File Type: pdf
Motorvated
Aug 16, 2013 10:30 PM
acibarich
Jun 5, 2013 08:57 AM
keithd21
Aug 2, 2012 07:14 PM
mlink
Jul 25, 2012 05:38 PM
LIVE4DISCO
Apr 20, 2010 06:54 PM
