Sponsored by: CARiD
Disco 2 Making Loud Knock
Old Oct 22, 2014 | 12:50 PM
Profitsx's Avatar
Default Disco 2 Making Loud Knock
I have a 2003 Discovery that I have owned for about a year. Last night it started making a real loud knocking noise so I drove it straight home. This morning I took a look and couldn't diagnose the exact cause, not sure if it's a blown head gasket or what. Anyone ever heard a Disco do this? Not sure if it's even safe to drive to the garage.
Old Oct 22, 2014 | 01:15 PM
dusty1's Avatar
sound like exhaust leak. possible head gasket, possible busted manifold. you should be able to locate it, it is going to be down at the head area
edit; manifold bolts all there? you can stick your hand down there, before it gets hot. you will feel it blowing on you.
Old Oct 22, 2014 | 02:58 PM
Profitsx's Avatar
Found the problem, a sparkplug wiggled loose and decided to do a combat jump out of the engine. Picked up a new plug, fired her up and she is purring like a kitten! Thanks for the suggestion, I was looking over the manifold bolts and saw the sparkplug wire out of place.
Old Oct 22, 2014 | 03:09 PM
dusty1's Avatar
well that will do it
Old Oct 22, 2014 | 03:28 PM
04duxlr's Avatar
I had one loosen up on my truck a while back. The previous owner had replaced the spark plugs but I would imagine they weren't tightened with a torque wrench. I highly recommend using one on the gasketed plugs on these aluminum heads.
velija
Apr 14, 2014 04:08 PM
David Simmonds
Jun 24, 2010 07:44 AM
tibyABv6
May 16, 2010 11:35 PM
targotsi
Feb 18, 2009 05:58 PM
stick
Jan 27, 2008 01:29 PM
