Sponsored by: CARiD
Disco 2 starter keeps turning over after started
Old Jul 8, 2015 | 06:26 PM
Tonyf365's Avatar
Default Disco 2 starter keeps turning over after started
I have a 01' Disco 2 and the starter gets stuck turning over after the vehicle is already started. when i shut it off the engine turns off but the starter keeps going. i can turn the key back to on and it'll start the engine without turning the key all the way to start. it does this till it blows the starter fuse. I've already changed the starter
Old Jul 8, 2015 | 11:08 PM
antichrist's Avatar
Please check your spelling, use punctuation and maybe make it a couple of sentences.
It's too late to try to decipher what you're saying exactly.
Old Jul 9, 2015 | 01:34 PM
justryan's Avatar
Sounds like you need a new ignition switch .......
Old Jul 9, 2015 | 02:37 PM
Racer X's Avatar
Either your ignition switch has gone bad, or the starter relay (is there a starter relay on these trucks?) is sticking and not releasing.
Old Jul 10, 2015 | 07:27 AM
OffroadFrance's Avatar
X1 could be the ignition switch not releasing, more like the relay holding in (defective) or the solenoid failing to release once engaged. Start with the simple stuff, the relay and then the solenoid and finally the ignition switch.
If all this fails take it to an auto 'sparky' for the pro knowledge
Old Jul 10, 2015 | 09:26 AM
drowssap's Avatar
disconnect the low voltage wire from the starter soliniod and reattach it . if it stops your soliniod is hanging up,
Tonyf365
Jul 10, 2015 02:55 PM
raven882
Jul 27, 2013 09:50 PM
SolbergFanBoi
Mar 5, 2012 07:05 PM
cationmoted
Sep 1, 2010 05:12 PM
JKK
Oct 5, 2008 07:57 AM
