Sponsored by: CARiD
Disco 2 Traction Control
Old Dec 16, 2015 | 11:11 AM
Stephen Disco 2's Avatar
8th Gear
how are you able to get to it ? I see you need to take half the centre console off.
Old Dec 16, 2015 | 11:13 AM
Charlie_V's Avatar
If that's to me, the switch is just behind the back of the front driveshaft on top of the transfer case. It is an odd shaped nut on a post. You just use the open end of a 10mm wrench to turn it clockwise to engage (it clicks so you know it is engaged). You can't see it from under the truck but once you've found it it is easy to put a wrench on.
There is a thread on how to make an actuator for about twenty bucks out of socket extensions, and it comes right up through the console.
Old Dec 16, 2015 | 11:42 AM
Charlie_V's Avatar
I'm sorry... I should add: you just swing under the passenger side of the truck with the wrench.
It would be very inconvenient if you already stuck. I have only engaged mine a couple of times, in order to drive with the front drives haft off.
michaelfisk
Apr 28, 2018 04:22 PM
gamecockdisco
Jul 12, 2010 08:34 AM
johnkbl
Dec 8, 2009 07:13 PM
daniep
Jan 26, 2009 01:58 PM
rodrick smith
Apr 13, 2007 06:09 PM
