Sponsored by: CARiD
discovery 2
Old Jul 16, 2012 | 03:26 PM
kunz209's Avatar
Default discovery 2
can anybody tell me how the 4x4 system works. does it have to be in low gear for the traction and abs to work when your wheeling or to make the tires lock up like have lockers in your diff.. and what does the brake drum do on the rear of t case.. and what does the m mode mean in low gear. sorry dont have owners manual yet.. thanks
Old Jul 16, 2012 | 03:30 PM
the brake drum is the parking brake, pulling it in an emergency is a good idea if you also are saying prayers rapidly at that point.
The 4WD works all the time, no 2WD unless you remove a drive shaft.
You can download the owners manual as part of the RAVE shop manual set below, if you just want the owners manual the second link lets you select just the manual you want.
Old Jul 16, 2012 | 03:35 PM
kunz209's Avatar
thanks so much...
