Discovery 2 Compressor Line lift system problem
I have a 2004 Discovery two that has a spaghetti Line leaking for the lift system. Land Rover Dublin tells me they cant find the hose to solve the problem. They say they searched 181 dealers.. Anyone have any ideas??
Any aftermarket manufacturers????
Need a solution. Any help appreciated..
Is there away to do away with this system all together???
yeah, if the air line is leaking then buy some 6 mm air line and cut to fit. You can buy the fitting that joins them by searching the range rover 96-02 catalogue. Its a small connector that will fit the hoses together.
but are you sure its not the air bags themselves.
you can also do a simple conversion from air to coil and the dealer can easily get the parts from the catalouge.
Then after the springs are installed have the guys change the configuration from air to coil spring. Takes five minutes max.
Kobloking
02-02-2013 08:19 AM
texci77
05-26-2012 08:33 PM
JerrodSteph
06-12-2011 06:04 PM
