Sponsored by: CARiD
Discovery 2 Compressor Line lift system problem
Old Aug 3, 2010 | 08:14 PM
DR.DREW2's Avatar
Smile Discovery 2 Compressor Line lift system problem
I have a 2004 Discovery two that has a spaghetti Line leaking for the lift system. Land Rover Dublin tells me they cant find the hose to solve the problem. They say they searched 181 dealers.. Anyone have any ideas??
Any aftermarket manufacturers????
Need a solution. Any help appreciated..
Is there away to do away with this system all together???
Old Aug 5, 2010 | 12:36 AM
Rovin4life's Avatar
yeah, if the air line is leaking then buy some 6 mm air line and cut to fit. You can buy the fitting that joins them by searching the range rover 96-02 catalogue. Its a small connector that will fit the hoses together.
but are you sure its not the air bags themselves.
you can also do a simple conversion from air to coil and the dealer can easily get the parts from the catalouge.
Then after the springs are installed have the guys change the configuration from air to coil spring. Takes five minutes max.
br0keit
Apr 25, 2020 12:49 PM
captain203
Dec 18, 2013 06:41 AM
Kobloking
Feb 2, 2013 08:19 AM
texci77
May 26, 2012 08:33 PM
JerrodSteph
Jun 12, 2011 06:04 PM
