Discovery II Transmission/Shifting Problem
Need help!! Having issues with 2003 Discovery II no modifications. After driving and vehicle placed into park, it will not go back into reverse or drive. Have to wait approximately 15-20 minutes and then it will work again. Shifts fine and runs fine when works, just have to wait before retrying. Recently changed xyz switch, transmission fluid and filter but still having same issue. Ideas?
Looking at your 'P' codes you have a bunch of oxygen sensor faults, I suspect you have the wrong sensors fitted or communication is poor. For certain Amigo you have mixture adaption issues.
The transmission fault is p0738 Torque converter module (TCM) engine speed output circuit low. The p0734 is 4th gear incorrect speed ratio.
Time to get someone into the transmission to diagnose the internals.
Can sound expensive!
