Sponsored by: CARiD
discovery tdi front cv
Old Sep 29, 2007 | 03:45 PM
rdsc1975's Avatar
Default discovery tdi front cv
hello could any body tell me what sort of job it is to change the front cv joint what tools do i need
many thanks rich
Old Oct 22, 2007 | 01:27 PM
lee666's Avatar
3rd Gear
Default RE: discovery tdi front cv
recently done mineyou have toremove thebrake assembly andhub seperate the swivel housing from the ball and you can then draw the shaft i done one side in 3 hours as for tools if you have a hub nut socket and good range of sockets and spanners you should be ok when rebuilding swivel ***** you should use a spring balance tool to set shim resistance on the housing pins i just used hand pressure to judge it. If you can get a manual it will guide you pretty well this job looks worse than it is.
dirkha
Feb 10, 2021 06:44 AM
MarcusMT
Jun 2, 2008 05:20 PM
stuman
May 19, 2008 11:24 PM
stuman
May 18, 2008 10:51 AM
dogsbody
Dec 31, 2005 02:14 PM
