Door Lock
Door Lock
Not a major problem, more a nuisance then anything else, but hope someone else has ran into this and can point me to a solution.
Left rear door lock, and back door haven't worked in about a year. Like I said, nothing more than a nuisance so never bothered to try to fix, but would like to know where to look first.
This site has been great at saving me HUGE $$$ and pointing me in the right direction, wish I could learn enough to give someone else a hand.
When I first got my DIsco II, the right rear electric door lock wouldn't lock or unklock with the fob, or master lock switch on the dash. I got my multimeter ready to start checking power and ground leads, pulled the inner panel off, and found...
...the lock actuator not plugged in.
I plugged it in, and it worked. Too bad not everything is that easy.
All the modern locks use basicly the same size holes. 2 1/8" through the door and 1" into the edge. The backset for the larger hole is pretty much standard as well. 2 3/8 for residential fixtures and 2 3/4 for commercial sets. Most now are 'convertable' meaning they can be switched from residential backset to commercial backset easily. Look for a bedroom/bathroom knobset in the color you want at the local home improvment store. They can guide you as to what will fit your needs!
Though the 2000 is getting old enough everything is now on sale (if you can find it)
bcolins
09-25-2012 08:40 AM
jfall
04-12-2012 03:26 PM
bcolins
11-08-2011 06:15 PM
