Sponsored by: CARiD
Door Lock
Old May 9, 2010 | 09:07 PM
itsbob's Avatar
Default Door Lock
Not a major problem, more a nuisance then anything else, but hope someone else has ran into this and can point me to a solution.
Left rear door lock, and back door haven't worked in about a year. Like I said, nothing more than a nuisance so never bothered to try to fix, but would like to know where to look first.
This site has been great at saving me HUGE $$$ and pointing me in the right direction, wish I could learn enough to give someone else a hand.
Old May 17, 2010 | 06:49 PM
ibis1's Avatar
Talking Lock problems
Bob,
What vehicle do you have and what do you mean by not working. A little more information would be nice. ibis1
Old May 17, 2010 | 08:55 PM
lordmorpheus's Avatar
When I first got my DIsco II, the right rear electric door lock wouldn't lock or unklock with the fob, or master lock switch on the dash. I got my multimeter ready to start checking power and ground leads, pulled the inner panel off, and found...
...the lock actuator not plugged in.
I plugged it in, and it worked. Too bad not everything is that easy.
Old May 18, 2010 | 03:27 AM
rosiasekha's Avatar
Default Landrover Owner
I am not sure of rules in UK... i am thinking of buying a freelander... it has got only 4 seats but the owner thinks its legal to sit 3 people on the back side... if its illegal wht happens when I am stopped by police?
Old May 18, 2010 | 05:12 AM
Samohajo@yahoo.com's Avatar
All the modern locks use basicly the same size holes. 2 1/8" through the door and 1" into the edge. The backset for the larger hole is pretty much standard as well. 2 3/8 for residential fixtures and 2 3/4 for commercial sets. Most now are 'convertable' meaning they can be switched from residential backset to commercial backset easily. Look for a bedroom/bathroom knobset in the color you want at the local home improvment store. They can guide you as to what will fit your needs!
Old May 18, 2010 | 05:47 PM
itsbob's Avatar
Originally Posted by ibis1
Bob,
OOPS, sorry.
2000 Discovery, Left Rear door, and rear hatch/door won't lock or unlock with the remote or from the hardwired switches in the truck.
Old May 18, 2010 | 07:45 PM
I would probably pull the interior door panels off the offending doors, make sure the lock actuator is plugged in (see my previous post), unplug it, and test with a multimeter to see if it is getting power when locks are activated.
Old May 19, 2010 | 12:23 PM
ibis1's Avatar
Talking Door locks
Bob,
With that vehicle and symptom, you are going to need new latch/actuator assys. Assuming they are plugged in. It's a common problem. ibis1
Old May 20, 2010 | 06:10 PM
itsbob's Avatar
Bob,
Thanks.. I haven't bought anything for the truck in at least a month. I'm due!
Though the 2000 is getting old enough everything is now on sale (if you can find it)
kpl1228
Aug 19, 2012 05:33 PM
CandiMan
Aug 24, 2008 10:35 PM
