Sponsored by: CARiD
ds1 no brake lights
Old Sep 21, 2014 | 09:11 AM
davek1's Avatar
Default ds1 no brake lights
My son has a 96 ds 1 with no brake lights if the cars running or not. I checked the fuses twice under dash and under hood all seem fine . I pulled the brake switch off and tested the wires. there is no voltage at the plug then I jumped the plug out with a wire and still no brake lights. if the fuse is good what should I check next. all other lights work including turn signals.
any ideas
thanks for looking
Old Sep 28, 2014 | 12:01 AM
TRIARII's Avatar
Brake light switch? Located under the brake pedal. Try replacing it and see if that solves the problem. Have you already checked/replaced your bulbs? How is the wiring to the rear lights?
Old Sep 29, 2014 | 04:52 AM
davek1's Avatar
wires and bulbs are good I jumped out the brake switch still no lights, Is there suppose to be voltage at the brake switch? if so where can I trace it from ? Thanks for your help.
Dave
jordamf
Aug 2, 2011 09:04 AM
ctystrickland
Feb 15, 2011 07:54 PM
USMC_Denver
May 8, 2009 12:41 PM
klh113
Dec 17, 2007 02:13 PM
