Sponsored by: CARiD
Electrical components location manual?
Old Aug 8, 2012 | 07:03 PM
Externet's Avatar
Default Electrical components location manual?
Is there such thing?
Am trying to locate Header 0292 (K109) from page 4.3 at the electrical circuits manual, for some troubleshooting on a dead door lock
Old Aug 8, 2012 | 08:39 PM
See attached. If you make the images on the circuits manual large enough, they show a CXXX-Y number, where XXXX is the conector number and Y or YY is the pin number. Slide over to the electrical library and the connector list and this is the sort of info you will find, in living color, on a Disco so clean it makes you sick.
On the locks, the IDM reverses voltage to the lock motors, lock or unlock. If the super lock motors have locked, then wire is broken, PITA.
File Type: pdf
Old Aug 10, 2012 | 10:46 AM
Externet's Avatar
Thanks again, Savannah Buzz.
Tried to remove the RH door latch to inspect and test the lock/unlock motors and gave up as after removing all attached to it, found that the glass channel is on the way to pull the assembly out. Am not going to risk the glass to lose alignment.
To tackle the troubleshooting from the 0292 header, I will need first to set an appointment with the chiropractor, and cure my knuckles and hands from the latch removal attempt.
A real pain in the everything !
I may have some confusion with the wiring, as the schematic shows a common wire and a another wire for each lock/unlock, total 3 wires per motor assembly. But the harness had more than that, 5 or 6 feeding the F RH lock motor assembly. What am I missing ?
Old Aug 10, 2012 | 12:08 PM
Over in Alarm section they show the other wires, for door sensors.
Old Aug 10, 2012 | 12:48 PM
Externet's Avatar
Great! So that is were the 'door open' signal comes from!, as there is no visible switches on the door frame... Good to know. Thanks.
Old Aug 11, 2012 | 06:32 PM
Rovin4life's Avatar
feel the door when you hit the lock. if it moves its bad. if it doesn't move then you have to check power and ground. the connector pulls out with the door panel off. If you want to pull off the door latch pul up the door frame about six to eight inches with the window down a third and you will have all the room in the world. just don't drop the little arm from the door latch to the handle. its a pain to get out.
booper169
Nov 16, 2010 09:39 PM
skinart
Engine & Internal
Apr 15, 2009 12:21 PM
DeepBlueWater
Feb 12, 2009 11:40 PM
Roveroh
Aug 7, 2008 09:42 AM
slainiae
Freelander
Oct 5, 2007 10:22 AM
