Sponsored by: CARiD
Electrical mysteries on RRC 1988
Old Mar 7, 2018 | 09:38 AM
1988RRC's Avatar
4th Gear
Default Electrical mysteries on RRC 1988
Hello all - Looking forward to some input from the group!
My 1988 Range Rover Classic has a number of fun brain busters, but the one that I can't figure out is this: The radio cuts out when I push the gas pedal down when it's cold. The second I let off the gas the radio comes back on. BUT it only does that until the vehicle warms up (about 2-3 miles of driving). Another sign it warms up is when I have the heat on to fan setting #2, it will blow somewhat hard until it warms up...then it slows down a bit and blows warmer air. Right at that moment, the radio works perfectly and the gas pedal + radio issue is gone.
Fuses have all been gone through. Battery is new within the last month. Alternator was checked by my local mechanic...but I don't 100% trust that's not the issue. Grounding issue? Voltage regulator issue?
Sometimes the wipers will cut out as well, but to solve that I just flip the fan to 2 or 3 (full blowing) and the wipers work again. Some wacky stuff! Any and all ideas are welcome, thank you!
Jordon
Old Mar 7, 2018 | 04:02 PM
I would check the chassis ground straps
Old Mar 7, 2018 | 04:04 PM
Shiftonthefly1's Avatar
Yep. I bet low voltage on the system
Old Jan 3, 2019 | 08:36 AM
1988RRC's Avatar
4th Gear
Solved
One of the main ground cables was broken off. Alternator was also pushing way too much to the battery and killed two batteries before I found the fix. New ground cable, new alternator and new battery and all the electrical is running top shape finally!
Old Jan 3, 2019 | 12:40 PM
Thanks for the follow up always helps folks later
ldaddy
Jul 2, 2016 06:05 PM
aBs0lut30
Jun 13, 2014 05:56 PM
jbdean
Jun 2, 2011 08:23 PM
coloboy
Jul 13, 2009 02:00 AM
jairocol
Feb 19, 2008 05:16 PM
