Sponsored by: CARiD
Engine light 2004 Discovery
Old Aug 2, 2011 | 10:00 AM
Martinsmith's Avatar
3rd Gear
Default Engine light 2004 Discovery
our engine light keeps coming on stating cylinder three miss-firing
even after two head jobs and every single sensor replaced as well as gas cap
even gas tank and electrical work by qualified Land Rover repair shop but not
dealer... this has been going on for months.... light only comes during very
hard acceleration... we are now at a loss....
Old Aug 2, 2011 | 10:58 AM
vintage_war's Avatar
It's a Rover, sometimes these things have no explanation.
Old Aug 2, 2011 | 07:45 PM
Have you replaced the plugs and wires?
Have they done a block test to check for cracks?
Old Aug 2, 2011 | 08:41 PM
Rovin4life's Avatar
possible cylinder slipping. best way to tell is to add coolant dye and drive it awhile. Then pull the plug causing the misfire, if its the color of the dye then its a dropped sleeve. seen it a few times. the four middle cylinders are always suspect of that issue when its intermittent and the best thing to do is always replace individual things to make sure it goes away instead all the plugs and wires and coil.
Old Aug 3, 2011 | 12:30 AM
socalrovershop's Avatar
when do you notice the misfire mostly? cold ? hot? under load? ive seen a couple times the lifter has taken a crap and valves hardley open. possible injector failure as well.
Old Aug 3, 2011 | 10:13 AM
3rd Gear
under hard acceleration.... injector was changed as was all cables and plugs....
Old Aug 3, 2011 | 10:14 AM
3rd Gear
normal engine operating temp....
Old Aug 4, 2011 | 01:08 AM
pull out the spark plug and make sure its gaped properly
osulax43
Jul 21, 2009 08:34 AM
osulax43
Jul 16, 2009 09:56 PM
tcbinaflash
Jan 8, 2008 04:23 PM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
