Sponsored by: CARiD
Freelander 1.8 2001 bad idle & head gasket?
Old Mar 26, 2018 | 10:34 AM
Joona Hintikka's Avatar
Default Freelander 1.8 2001 bad idle & head gasket?
Hello, I just bought my first Land Rover. I live in Finland and couldn't get much help here. Sorry if my English is poor...
First of all my Freelander has bad idle. Engine vibrates a bit and rpm is moving up and down a bit. When accelerating the car runs good. Only fault code is crankshaft position sensor. And it's just now and then. Not always. I think that is not the issue.
Second, I have some oil mixed to the coolant. Temperature is ok, there's no pressure in the system and no water in the oil (luckily). I think i try to fix it with a Holts Wondarwelt liquid. Is there possibility that the oil is coming from the gearbox (manual)? Or is the engine oil the only option?
An last. I have a problem with the head lights. Some times the head lights stays on no matter what. After few minutes of adjusting the key and light switch, the lights might go off. Sometimes I have to take the battery off. After that the lights go off. Where is the relay located? Is it the same relay that controls the high beams?
Many, many thanks for any info. I appreciate it very much!
GiGi La Luz Ramone
Aug 31, 2013 04:46 PM
Draayer
Apr 25, 2011 06:39 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
LRDon
Apr 16, 2008 12:51 AM
dc10freighter
Jun 15, 2007 09:47 AM
