Sponsored by: CARiD
freelander fault code reader
Old Oct 3, 2010 | 07:02 AM
bigtony's Avatar
5th Gear
Default freelander fault code reader
Hi, I am new here but would apreciate your help,I have a 03 freelander1, that I would like to be able to read the fault codes on,can anybody point me in the right direction
Old Oct 3, 2010 | 07:32 AM
They don't take any special reader, all OBD2 readers will get the job done, the only difference is that as they become more expensive they will do more for you in fixing problems.
I bought a 3130 from Amazon for around $134 after reading the link below. Check it out.
http://www.canobd2.com/Products/Tools.aspx
Make sure you check Amazon's prices, they are the best.
Old Oct 3, 2010 | 07:41 AM
bigtony's Avatar
5th Gear
many thanks for quick answer, but one more question , where do you plug it in on the vehicle
Old Oct 3, 2010 | 11:14 AM
bigtony's Avatar
5th Gear
ok found the obd socket, have looked at varios scanners and fancy the AUTEL MAXISCAN MS509 ,would apreciate any veiws on this or any other scanners
sayeedA
Feb 25, 2014 12:35 PM
seanyh
May 2, 2013 08:10 AM
scherer
Off Topic
Nov 26, 2012 12:20 AM
